Rearranging Primitive for each blocks to original position
nimish
I am trying to rearrange all the primitive blocks using for loop but couldn't find a solution. I want to revert all the pieces back to their original place from the centroid. I used 2 transform nodes in the for each node to bring all the pieces to the origin. Now, I want to bring all the pieces back to their original position aka the first screenshot.
Heres the hip file. Thank you for reading :)
reaarange_test.hipFetching info...
Edited by nimish
  On 6/14/2021 at 9:58 AM, Dweeble said:
Store point positions before the loop and restore them afterwards? Be aware that the loop will split the points so make sure to fuse them back.
reaarange_test.hiplcFetching info...
Expand
Thank you for the file @Dweeble
One more question, is it possible to animate the pieces return back to their original place?
