Procedurally create groups from attribute values with corresponding name
Im working with osm data and which has a "building" attribute that contains values like garage, residential, apartments etc... and there is usually varying values depending on the location that the data is taken from. What im trying to do is create a group for each value that is named with the value. For example i have an osm file with the building attribute and a value of "garage" which needs to be turned into a group called garage, referencing the value for its name. I know i can reference attribute values as groups by doing @building=garage but then its not procedural and would not create a group for each value type. Not really sure how to do this and would appreciate any input!
