Vellum grains Expanding Issue
Mark01
Hi all ,
I have a sandbox filled with vellum grains. I have the grains settle and then after a few frames part of the grains start to expand slightly.
Has anyone experienced this issue of know what could be causing this?
Thanks so much! :)
  • 3 months later...
On 30/10/2021 at 7:53 PM, Xtradite said:
Hey, did you ever find a solution/cause to the problem? :)
I don't remember exactly what is was that solved this, however a few things I ended up doing;
1. Reducing gravity
2. Using geometry and pinned/gluing the grains to the geometry so that it's all static and only areas collided with are unpinned.
This thread and the hip file in one of the posts might be useful to anyone with this problem :)
