Houdini Engine installation on older UE4 versions
Matt688
Has anyone successfully installed the Houdini Engine on older versions of unreal?
I am locked into Unreal Engine 2.24 to use the Carla Autonomous Driving Simulator with UE4. We are locked into this Unreal version until the Carla team updates to a current version.
I have tried a few versions of Houdini Core to try to find matching versions on sideFX gitHub repo.
The prebuilt versions will load into UE4 as a typical plugin but have no functionality or parameters when I bring in an otl. The otls is not the issue, i have tried a few from orbolt and I cannot sync to my version of Houdini.
I have tried to build an older version from source and receive non descript errors while using runUAT.bat - following this tutorial:
Any input or links to other resources would be appreciated.
Thanks!
