saca Posted July 9, 2021 Share Posted July 9, 2021 hi, I have set deadline Job-Name by python script, from $HIPNAME and "python-date". Some Output(ROP) are executed into dependencies. so the "date" strings are changing on ROP by ROP because the submitting needs some seconds. of course we can use minute, but the submitting needs over one minutes, the batch group is split some groups. *)bad example, splitted some batch-groups <s001_001_Fx_fire_v001.hip [2021-07-09 15:23:48.642000]> |-s001_001_Fx_fire_v001.hip/out/abc/vdb_rocks <s001_001_Fx_fire_v001.hip [2021-07-09 15:23:49.343000]> |-s001_001_Fx_fire_v001.hip/out/vdb/vdb_fire <s001_001_Fx_fire_v001.hip [2021-07-09 15:24:03.132000]> |-s001_001_Fx_fire_v001.hip/out/ass/Ar_fire |-s001_001_Fx_fire_v001.hip -Arnold- /out/ass/Ar_fire *)the case I want <s001_001_Fx_fire_v001.hip [2021-07-09 15:23:48.642000]> |-s001_001_Fx_fire_v001.hip/out/abc/vdb_rocks |-s001_001_Fx_fire_v001.hip/out/vdb/vdb_fire |-s001_001_Fx_fire_v001.hip/out/ass/Ar_fire |-s001_001_Fx_fire_v001.hip -Arnold- /out/ass/Ar_fire *)the python code import datetime hipFile=hou.expandString("$HIPNAME") dt=str(datetime.datetime.now()) return (hipFile + '.hip [' + dt + ']') do you have any good idea to being one batch group names from date? like that the way store value other variables, i do not know it in houdini. thanks. Quote Link to comment Share on other sites More sharing options...
acey195 Posted July 11, 2021 Share Posted July 11, 2021 You probably want to store the time in a previous node, that does not "recook" between your outputs you can use a detail (global) variable for that, if you need code reference for that, look for: hou.node and hou.geometry in the documentation then you can reference this stored value in your rop nodes, that should not change, unless you change the input, above the node that stores the time. Quote Link to comment Share on other sites More sharing options...
saca Posted July 12, 2021 Author Share Posted July 12, 2021 (edited) very thanks your idea. i will try and report some days later. Edited July 12, 2021 by saca Quote Link to comment Share on other sites More sharing options...
j00ey Posted July 22, 2021 Share Posted July 22, 2021 I have a related problem... I'm making an HDA to do an OpenGL render, then composite the result of that with some details, like shot name etc and I want to add the date and time the render was started, then finally spit out an mp4. So my setup is using a TOPnet to do the OpenGL render, then the COPs one and then FFMPEG the result... I thought I had it working by using a prerender script in the OpenGL ROP that set the comment field on itself, then I can reference that with a font COP. It was working while I was testing but if I run it through TOPs it comes out blank. I've changed it for now so that the timestamp is live - I've put an expression on the comment field itself and am referencing that but of course if the render takes more than a minute the value increments... It's not a big deal but I'd like to figure out how to set the timestamp from when the render is started. this is what I set on the Pre Render Script parm of the OpenGL ROP - it works in my session but not through TOPs: from datetime import datetime now = datetime.now() date_str = now.strftime("%d/%m/%Y") time_str = now.strftime("%H:%M") now_str = "date : " + date_str + " time : " + time_str rop = hou.pwd() rop.parm('vm_image_comment').set(now_str) return 1 so now I have this script on the comment field instead : from datetime import datetime now = datetime.now() date_str = now.strftime("%d/%m/%Y") time_str = now.strftime("%H:%M") now_str = "date : " + date_str + " time : " + time_str return now_str which works but the time ticks up as the render progresses Thanks for reading Quote Link to comment Share on other sites More sharing options...
j00ey Posted July 23, 2021 Share Posted July 23, 2021 In case it's of use to anyone I got round this by making a null with 2 string parms, one called 'now' with an expression as above and one called 'snapshot'. I put a callback on the TOPs cook button to set 'snapshot' using the value on 'now' and reference that in my font COP. So it just gets set the once at the start of cooking and so doesn't tick up... Quote Link to comment Share on other sites More sharing options...
saca Posted October 4, 2021 Author Share Posted October 4, 2021 >like that the way store value other variables, i do not know it in houdini. Add the content you want to preprocess to "preCode" string widget and add "My_Submit" button instead of the standard "(Deadline)Submit" button. If you hide the standard "Submit" button, you can use it as same. in this way set date-time at once. Quote Link to comment Share on other sites More sharing options...
