viktorofobos Posted July 27, 2021 Share Posted July 27, 2021 Рello everyone, I have a problem, please help. Quote Link to comment Share on other sites More sharing options...
Fenolis Posted July 28, 2021 Share Posted July 28, 2021 Hello there! If you are planning to work in NURBS, you may want to consider setting your primitives to be of type NURBS and use Surfsect instead of polygon Boolean. Quote Link to comment Share on other sites More sharing options...
viktorofobos Posted July 28, 2021 Author Share Posted July 28, 2021 thanks for the answer but I've already used the Surfsect, and it doesn't cut a hole in the sphere. Quote Link to comment Share on other sites More sharing options...
Fenolis Posted July 29, 2021 Share Posted July 29, 2021 This is the part where I paraphrase@Noobini: "Share your file so we can figure out how you set it up and diagnose your issue" since it works for me. Quote Link to comment Share on other sites More sharing options...
viktorofobos Posted August 3, 2021 Author Share Posted August 3, 2021 Thank you very much for the picture, I repeated the same in the licensed version houdini. and I succeeded. For some reason in the non-commercial version of the it did not cut a hole for me. thank you again Quote Link to comment Share on other sites More sharing options...
