Mzigaib Posted July 30, 2021 Share Posted July 30, 2021 (edited) I came across this interesting Blender tutorial where the author uses math nodes to recreate a 2D ngon shape similar like using COPs to create patterns and I decided to give a try translating it in Houdini using VEX and I got stuck trying to find a VEX function similar to a Blender one which I couldn't so I am sure that a smarter brain could easily solve this exercise so here is the challenge. This is the tutorial link and around 12:30 he explains the theory behind the function 'snap' and at 23:57 it shows it in action: link Which basically it returns the closest value that B[] is from A. I hope it makes sense. Any tips? Thanks in advance. Edited July 30, 2021 by Mzigaib Quote Link to comment Share on other sites More sharing options...
animatrix Posted July 30, 2021 Share Posted July 30, 2021 Hi, VEX has a lot of sample functions for these, for example sample_circle_uniform: https://www.sidefx.com/docs/houdini/vex/functions/sample_circle_uniform.html So you can do something like this in a Detail Wrangle: int count = chi("count"); for ( int i = 0; i < count; ++i ) { float u = float ( i ) / count; vector2 uv = set ( u, 1 ); vector2 p = sample_circle_uniform ( uv ); vector pnew = set ( p.x, 0, p.y ); addpoint ( 0, pnew ); } Quote Link to comment Share on other sites More sharing options...
Mzigaib Posted July 30, 2021 Author Share Posted July 30, 2021 (edited) That's really cool! One more trick learned. My goal was to try to use the formula on the tutorial to draw in COPs the ngon shape with VEX. After a lot of trying and error I could translate the formula to COPs using VOP COP and the hardest part was to trying to figure out the different functions that are created specific for Blender. That being said I was able to find what the 'snap' function and what it does is simple: float snap = floor(val1/val2)*val2; So after that was just a matter of assemble the formula in the inline VOP inside the VOP COP and vua-la, It worked! So I did: distance = length($uv); angle = fit(atan2($uv.y,$uv.x),-$PI,$PI,0,2*$PI); float val = (2*PI)/$n; float snap = floor($angle/val)*val; float x = $r*sin((($n-2)*PI)/(2*$n)) / sin(PI-($angle-snap)-((($n-2)*PI)/(2*$n))); $dist = x > distance; Being the $uv the x/y pixel positions offseted to the center and $n being the ngon sides and $r being the radius parameters. Thanks for the trick tip that was really useful. Edited July 30, 2021 by Mzigaib Quote Link to comment Share on other sites More sharing options...
