Creating A Rop Hda Problem
lisux
Hi everybody.
I am creating an HDA to bake attributes using the mantra -u option.
My HDA only have a Mantra ROP, is only a wrapper for a Mantra render, but any time I try to render I get the same error:
mantra: Unable to find object '/obj/model'
The mantra command line I am using is:
mantra -b Float -V 1 -u "`chs("../obj")`"
Here I reference to tha obj parameter of the HDA.
It seems that there is no problem with the command line expression because ir returns exactle the path I want, and this path, /obj/model, is correct, even more if I render usinga regular Mantra ROP and in the command line I type:
mantra -u /obj/model
It work perfectly.
So why when I use render using a Mantra ROP embebed into a HDA it fails?
Somebody have suffered similar problems?
Thanks.
Hey, I ran into this problem before and I think you are having the same issue as I did. You need a full path to your geo. It doesnt seem to like relative paths, so if you use opfullpath(), it should fix that problem.
mantra -u `opfullpath("../model")`
Thanks SpenderL, but it seems that this is not the problem.
I am using absolute path always, anyway I have changed the command line expression with this:
mantra -b Float -V 1 -u `opfullpath(chs("../obj"))`
But still the same error.
It seems like the mantra -u doesn't like to work into a HDA.
CODE
hmm...not sure why its not working. I created an HDA that bakes ambient occlusion that uses the exact syntax
...and it works fine. Im at work now, so I will have to wait until I get home this evening, but once I do Ill upload my HDA to the exchange and you can take a look at it.
