Flip sim collision inside a box isn't colliding
Jmg07
In the attached hip file i've put a sphere in a box - the box is a vdb from polygons and the sphere is a flip object.
But the collisions don't seem to be working. I set the voxel size on the vdb to .001 and in the static object the proxy volume is set to the vdb.
A bit confused about it.
Thanks
test_vol_flip_sim.hipnc
12 hours ago, Jmg07 said:
Thanks
in static object node  turn on " Invert Sign "  bcuz ur Flip Source is inside the SDF Volume
@Ultraman thanks. I still struggle with all the various checkboxes and options in Houdini - and while I watch quite a bit of tutorials on youtube, etc. still find it hard to work out what all the bits and pieces are doing - especially with volumes. so if you have any good references that'd be cool. cheers
Fallow Applied Houdini Video Tutorials is a Great Course for learning
