Eyeracker Posted August 9, 2021 Share Posted August 9, 2021 Hello Everyone, How can I add new location links to the open menu in Houdini? I know that you can add locations with the '+' sign, but it's confined to a specific project only. So is there a way to add it as a global variable? Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted August 9, 2021 Share Posted August 9, 2021 Hi, plus button "Add Selected Directory to Favorites" in Open, Save, Import, (etc) windows creates a permanent link to directory, at least it works like so for me. Quote Link to comment Share on other sites More sharing options...
Eyeracker Posted August 9, 2021 Author Share Posted August 9, 2021 Hello vicvvsh, Thank you for the reply. But is there a way to make a directory in the $FOLDERNAME format? like $HIP, $JOB etc. Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted August 9, 2021 Share Posted August 9, 2021 (edited) You can define directory in houdini.env file, i.e.: MYDIR="/path/to/your/folder" since that you can using variable $MYDIR like $HIP, $JOB etc. Or you can use packages https://www.sidefx.com/docs/houdini/ref/plugins.html Edited August 9, 2021 by vicvvsh 1 Quote Link to comment Share on other sites More sharing options...
Eyeracker Posted August 10, 2021 Author Share Posted August 10, 2021 This is great. Found some good info in that link you posted. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
