Redshift - Achieve water look from reference image
Xite
What I want to achieve on my render:
I know that I need very low particle seperation so the turbulent spots are crispy and visible.
My test rendering with redshift: https://www.youtube.com/watch?v=CL8iC5EQaoY
My Questions:
- I don't use any ocean tools for this; just an emitter that hits the wavebreaker collision: Should I better use ocean tools instead plain FLIP and an emitter?
- I used a 50m x 40m x 20m scale FLIP tank to somewhat get realistic scale with 0.04 particle sep. It took me about 4 hours to sim and mesh 150 frames. Is this overkill and should I go much lower on the scale?
- Entagma made a tutorial about adding the turbulent areas of FLIP as an attribute to the material. I did the same but the white parts are flickering very hard for me when rendered. https://www.youtube.com/watch?v=DhqC13Z_hYc&t=774s
Basically how can I reproduce the same look from the reference image with houdini and redshift?
Many thanks in advance
