Oidy Posted October 27, 2021 Share Posted October 27, 2021 I have a some simple restblend workng, I have the vellum solver in a dopnet and copies of my geo getting activated every 10 frames. The problem is the restblend is only appearing on the first instance. Then I tried to use the object level restblend node, and that way the copies were being generated at the frame of the transformation, but were remaining half blended or whatever frame they were emitted. I just want the restblend movement to happen on every copy, preferably keeping its own original time since "birth" so each copy will spawn> keep original shape for x frames > restblend after x amount of frames to new shape. Is this a forloop situation? Quote Link to comment Share on other sites More sharing options...
Oidy Posted October 28, 2021 Author Share Posted October 28, 2021 So basically the old pig head fountain but where each copy has restblend happening to each copy, hopefully at relative timing to their birth. Quote Link to comment Share on other sites More sharing options...
