sebkaine Posted November 5, 2021 Share Posted November 5, 2021 Hi guys, I have a strange problem. - i have a FLIP DOP set to start at F75 + Enable automatic resimulation Off - in my dop output i set the frame range to F75 to F200 - in my dop IO i also set the frame range to F75 to F200 - i do a Ctrl+clic on the brain to be sure that the cache is empty But whatever i do , houdini don't care, when i am evaluating my scene between F1 to F74 houdini still try to evaluate my DOPS again and again, this is pretty annoying. Do you guys have any idea on what am i doing wrong ? or any tips to fix this ? Thanks for your time. Cheers E Quote Link to comment Share on other sites More sharing options...
sebkaine Posted November 21, 2021 Author Share Posted November 21, 2021 Well i still have strange behavior of DOP's trying to evaluate all the time. I did find a working solve for this. Each of my DOPs output is connected to a switch node, one is the DOP network the other a NULL, then i have a master null at /obj level that control all the switch, thus i can activate and deactivate everything i need. and this does work , when all switch are set to NULL houdini doesn't evaluate anything. I did prefer this method over always playing with the brain logo and the manual / update switch. Quote Link to comment Share on other sites More sharing options...
Shantanu Posted November 30, 2021 Share Posted November 30, 2021 can you share the hip file? Quote Link to comment Share on other sites More sharing options...
sebkaine Posted December 17, 2021 Author Share Posted December 17, 2021 Thanks for your answer Shantanu, unfortunatly i can't as it's a NDA work. Quote Link to comment Share on other sites More sharing options...
