Convert Packed Bounding Box to Polygon?
galagast
So far, this one worked :D
create_attributes (run over points)
matrix ident = ident();
addpointattrib(0, "transform", ident, "matrix");
get_intrinsic_attributes (run over points)
int pt = addpoint(0, {0,0,0});
// get bound size
float bounds[] = primintrinsic(0, "packedbounds", @ptnum);
float size_x = abs(bounds[0]-bounds[1]);
float size_y = abs(bounds[2]-bounds[3]);
float size_z = abs(bounds[4]-bounds[5]);
vector scale = set(size_x, size_y, size_z);
// set transform
matrix tm = primintrinsic(0, "packedfulltransform", @ptnum);
vector pos = primintrinsic(0, "pivot", @ptnum);
pretranslate(tm, pos);
prescale(tm, scale);
setpointattrib(0, "transform", pt, tm);
removeprim(0, @primnum, 1);
  • Like 2
