danielsweeney Posted November 12, 2021 Share Posted November 12, 2021 Hi Everyone, Just wondering if someone could shed some light on this. I'm copying values from one node to another for every Parm. but when using setFromParm(src) on a parm that has keyframes. it seems to copy the values across. but I cant see the keyframes in the timeline or any of the editors? whats gives? is this the proper way to do this or is there an extra step or another method? Any tips would be great thanks so much for your help. Daniel Quote Link to comment Share on other sites More sharing options...
danielsweeney Posted December 9, 2021 Author Share Posted December 9, 2021 hi again, Just in case someone stumbles over this problem. Seems the way around it is to use two functions in conjunction. the setFromParm(src) seems to set all values correctly even referenced Parms. but the keyframes don't seem to work fully. so you have to check if the parm in question has keyframes and if so. use setKeyframes(keyframes) instead for those Parms. Hope that helps anyone that runs into it. cheers Daniel Quote Link to comment Share on other sites More sharing options...
