Portal light = Portal light?
In Maya a Portal light redirects lights from outside though itself to the inside, a bit like a wifi repeater.
In Houdini, I've watched this: https://www.sidefx.com/tutorials/portal-light/
but there was no light outside to redirect, it seems the portal light (actually an environment light) is emitting light itself. Is the portal light in Houdini just a geometry light?
Why does it matter? I need the exact light coming out of the hdri to be pushed inside / redirected using the portal light.
ipr 1. no portal light, just hdr, no other lights
ipr 2. added a grid covering the window, and turned it into a "portal light", kept everything default, which clearly ruins the realism from the hdr because I'm adding a flat white colour.
ipr 3. changed the "portal light" color to red
ipr 4. tried to repair the damage by at least adding a texture from the hdr instead of the flat white colour. which turns it into a area light with a texture.
A portal light should be just the middleman: takes light from outside and reroutes it inside, shouldn't emit.
The portal light in Houdini is NOT a portal light, it's a redundant duplicate of an area light.
