[SOLVED] Convert String Attribute to Int Attribute? (No not the atof() expr)
bentraje
Is there a way I can change the string attribute to an int attribute.
For example, base data is
BEFORE
ptnum, name
1,  joint_a_sel,
2, joint_b_sel,
3, joint_d_sel,
4, joint_a_sel,
5, joint_c_sel,
resulting data would be like
AFTER
ptnum, name, name_int
1,  joint_a_sel, 1
2, joint_b_sel, 2
3, joint_d_sel, 4
4, joint_a_sel, 1
5, joint_c_sel, 3
I'm not sure what's the proper nomenclature for this task but hopefully the before and after makes it clear.
Is there a way around this?
P.S. AFAIK, the atof() expression is only for strings that already looks like a number but is labelled as a string.
Edited by bentraje
