Setting curve in popcurveforce node crashes Houdini
robbiecooper
Hi All
I'm trying to get some points, which I generated from a mesh using the scatter node, to move along a curve using a popnet with a popcurveforce node in it. A few seconds after I set the curve in the popcurveforce node, the editor crashes with this error; 29608: Fatal error: Segmentation fault.
I'm assuming i've done something wrong. I re-installed NVidia studio drivers just in case, and its still doing it. Anyone know what the problem could be?
Edited by robbiecooper
