Houdini Mantra not reading UDIM sequence
Hi All,
I have a strange issue involving Houdini not reading a UDIM sequence. The file names are ordered as BaseColor.1061.exr through to BaseColor.2994.exr I can read the files into COPs just fine when reading them as a frame sequence ($F) but trying to read the as a UDIM sequence into a Mantra texture node, I get "Error reading file". I haven't come up against this problem before, I have verified the files aren't corrupt and run through the sequence in Nuke. There are a few gaps in the numbers but I didn't think that would cause a problem. If anyone has any insight it would be greatly appreciated.
Thanks, Tom
  • 1 month later...
Make sure that you're using the correct syntax for UDIMs in the filename.
The syntax for UDIM files is filename%(UDIM)d.ext where %(UDIM)d takes the place of the frame number. So if you had image1001.exr, image1002.exr, it'd be image%(UDIM)d.exr.
https://forums.odforce.net/topic/25986-what-is-the-udim-multi-uv-workflow-in-houdini/
