VEX luminance vs @Cd length, and Max and Min luminance
anicg
In the attached file I've calculated the Cd vector length which I was led to believe is the brightness, but then there is luminance function that's gives different values than the Cd length.
Do you know why there is a difference?
In part two of the code I'm trying to find the brightest and the darkest using max(luminance.. and min(luminance ... I don't know how to make it work to get just one value for the max and one value for the min (for all the points).
VEX_luminance_vs_Cd_Length.hiplc
The luminance() function is calculating the perceived brightness. It's weighting each color channel (R, G, B ) differently.
The min() and max() functions will just return the smallest or highest component of a vector (R, G or B). To get the global maximum and minimum value of an attribute, you would set a detail attribute first and access it in another wrangle:
Edited by konstantin magnus
