SohailNordin Posted December 26, 2021 Share Posted December 26, 2021 Hi, I'd like to know the difference between the two and when I would use one over the other Quote Link to comment Share on other sites More sharing options...
madebygeoff Posted December 27, 2021 Share Posted December 27, 2021 The normal SOP really does one thing and one thing only. It calculates normals and sets the cusp angle. I think of the facet SOP as more of a multi-purpose clean-up tool. First and foremost, it allows you to control how points are shared or not between polygons. Are points shared between adjacent polygons or are they kept unique per polygon. It then adjusts the normals based how you would like them to be calculated. Normals is primarily about calculating normals. Facet is primarily about consolidating or unique-ing points and calculating normals can be done before or after that process. That said, there is a lot of overlap. Quote Link to comment Share on other sites More sharing options...
