Atom Posted January 6, 2022 Share Posted January 6, 2022 (edited) With the Karma ROP available in the /out context, I wanted to conduct a few test renders to compare Lops Karma with Sops Karma. Here is a /out/karma1 render of the patchwork pig that Konstantin presented with the lights extracted from Lops. You can place this short script in a shelf tool. It tries to extract the lights from Lops and generate companion ones in Sops. # Scan the /stage context for any lights and create companion lights in /obj. # Atom 01-06-2022 import hou, re def returnValidHoudiniNodeName(passedItem): # Thanks to Graham on OdForce for this function! # Replace any illegal characters for node names here. return re.sub("[^0-9a-zA-Z\.]+", "_", passedItem) def childrenOfNode(node, filter): # Return nodes of type matching the filter (i.e. geo etc...). result = [] if node != None: for n in node.children(): t = str(n.type()) if t != None: for filter_item in filter: if (t.find(filter_item) != -1): # Filter nodes based upon passed list of strings. result.append((n.name(), t)) result += childrenOfNode(n, filter) return result def migrateLights(node_path): node_target = hou.node("/obj") if node_target != None: light_nodes = childrenOfNode(hou.node(node_path),["Lop light"]) #Other valid filters are Sop, Object, cam. for (name, type) in light_nodes: node_candidate = "%s/%s" % (node_path, name) n = hou.node(node_candidate) if n !=None: # Create the Houdini light node. light_name = returnValidHoudiniNodeName("%s" % name) node_light = hou.node("%s/%s" % ("/obj", light_name)) if node_light == None: # Create new light. node_light = node_target.createNode('hlight::2.0',light_name) else: print ("skipping creation of %s." % light_name) # Position and rotate light. node_light.parm("tx").set(n.parm("tx").eval()) node_light.parm("ty").set(n.parm("ty").eval()) node_light.parm("tz").set(n.parm("tz").eval()) node_light.parm("rx").set(n.parm("rx").eval()) node_light.parm("ry").set(n.parm("ry").eval()) node_light.parm("rz").set(n.parm("rz").eval()) # Migrate light type. lop_index = n.parm("lighttype").eval() ary_remap_index = [5,7,2,0,3,4] ary_lops_types = ["cylinder","distant","disk","point","rectangle","sphere"] ary_hlight_types = ["point","line","disk","grid","sphere","tube","geometry","distant","sun"] t = ary_hlight_types[ary_remap_index[lop_index]] node_light.parm("light_type").set(t) node_light.moveToGoodPosition() # Program starts here. path = "/stage" #path = "/obj/lopnet1" migrateLights(path) Edited January 6, 2022 by Atom Quote Link to comment Share on other sites More sharing options...
