Hai Nguyen Posted January 8, 2022 Share Posted January 8, 2022 Hi, I'm following a tutorial that uses Redshift to create instance points in sop instead of using copy to points node. However, when I render in Arnold, create an attribute named instancefile and put an .ass file directory like they do (they put .rs file instead .ass), it renders white spheres instead of my object. I'd like to ask if I set up something wrong or is this a feature only for RS. How can I make it work in Arnold? Sorry for my bad explanation. You can see images below to see my issue. This is a setup using copy to points node. I want to do the same for instance points. Instead, I have white spheres which I believe these are points. No matter what objects I put in instancefile node, they always render out white spheres. This is the file just in case you need: test.hip Thank you for helping me. Quote Link to comment Share on other sites More sharing options...
Hai Nguyen Posted January 18, 2022 Author Share Posted January 18, 2022 Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
dleonhardt Posted January 18, 2022 Share Posted January 18, 2022 For Arnold you need to add the 'ptinstance' Render Property to the Geo node. Quote Link to comment Share on other sites More sharing options...
Hai Nguyen Posted January 31, 2022 Author Share Posted January 31, 2022 On 1/18/2022 at 10:45 PM, dleonhardt said: For Arnold you need to add the 'ptinstance' Render Property to the Geo node. Thank you so much! It worked! Quote Link to comment Share on other sites More sharing options...
