machinainfinitum Posted January 16, 2022 Share Posted January 16, 2022 Hi brains ! Need help! I've got a mesh (as an example I'll use pig head) and I'm using a "mesh slice" node to split it in different parts, using $F as index, basically every frame I see a different slice of the pig. Tried to export in fbx using rop fbx but can't find a way to create a different file for each frame. I can export in obj and it works by saving each frame in a separate file "test$F.obj" but does not work with FBX rop, I always get only one FBX file.. Any idea ? Thanks in advance, happy houdiniiiing ! MeshSliceFBX.hip Quote Link to comment Share on other sites More sharing options...
sebkaine Posted January 17, 2022 Share Posted January 17, 2022 (edited) I thinks it's because this is the way FBX has been devised. basically FBX export animation in two ways : - the most popular in game where you store animation with xform transform and bones + weight map. - the other is by exporting a vertex animation cache like the .abc format, in that case FBX export only one FBX file and store the animation in a file point cache .fpc If you want to export per frame .fbx you just want to hack the way the format has been devised. it looks to be possible thought there is a scene by tomas here : https://www.sidefx.com/forum/topic/54398/?page=1#post-349575 why do you prefer FBX over .abc for vertex cache file export ? why per frame ? Edited January 17, 2022 by sebkaine Quote Link to comment Share on other sites More sharing options...
Alain2131 Posted January 22, 2022 Share Posted January 22, 2022 (edited) Here's my take on it It's not polished or anything, it just works. Basically, it's a foreach loop, set to By Count, which is controlled by a frame range attribute. Within the loop is a timeshift tied to the loop's iteration, as well as an FBX Export with the same loop iteration in the filename. Finally, a python sop simply does a pressButton() on the FBX. (The execution is handled through the Stop Condition of the loop. The subnet's Export button sets it to 0, force cook, then sets it back to 1) Anyways here's the file (19.0.455), hopefully that helps. export_separate_fbx_per_frame.hiplc Cheers ! (I took that as a fun mini tool-building exercise, but sebkaine's link has a few other solutions that works just as well) Edited January 22, 2022 by Alain2131 Quote Link to comment Share on other sites More sharing options...
machinainfinitum Posted January 27, 2022 Author Share Posted January 27, 2022 Thanks everyone ! Got it working with Alain's setup, thanks for that Emmanuel I need separate fbx because the mesh I'm slicing is around 60gb in size, can't create one unique abc or fbx for an easier file handling during import in Unreal Engine. Cheers Quote Link to comment Share on other sites More sharing options...
sebkaine Posted January 27, 2022 Share Posted January 27, 2022 ahah 60GB into UE you definitly got a good reason. .abc suck in UE it looks that they still label it experimental features https://docs.unrealengine.com/4.27/en-US/WorkingWithContent/Importing/AlembicImporter/ as it was already experimental 5 years ago, i guess it will stay that way forever before being replaced by usd. Quote Link to comment Share on other sites More sharing options...
xrossfader Posted April 11, 2025 Share Posted April 11, 2025 On 1/21/2022 at 7:27 PM, Alain2131 said: Here's my take on it It's not polished or anything, it just works. Basically, it's a foreach loop, set to By Count, which is controlled by a frame range attribute. Within the loop is a timeshift tied to the loop's iteration, as well as an FBX Export with the same loop iteration in the filename. Finally, a python sop simply does a pressButton() on the FBX. (The execution is handled through the Stop Condition of the loop. The subnet's Export button sets it to 0, force cook, then sets it back to 1) Anyways here's the file (19.0.455), hopefully that helps. export_separate_fbx_per_frame.hiplc Cheers ! (I took that as a fun mini tool-building exercise, but sebkaine's link has a few other solutions that works just as well) 2 years later and this just made my day. I modified it to work on named prims and added a naming property to the subnet so I can drop it into a named folder. Thank you! 1 Quote Link to comment Share on other sites More sharing options...
