breadbox Posted January 17, 2022 Share Posted January 17, 2022 I'm trying to match the sound keys effect from After Effects.. The spectral CHOP node looks like its close, but im not sure how to properly set the parameters to analyze the audio file to match perfectly. In my example (see pic) its getting some amplitude, but its not splitting the frequency spectrum into the base, mid, and high tones accurately. Any tips how to create a graph that matches what After Effects Sound Keys does? Quote Link to comment Share on other sites More sharing options...
Librarian Posted January 19, 2022 Share Posted January 19, 2022 @breadbox when you have "f@weight on points Houdini Its easy " I think .. Here you have approach that I use for Spectrum(weight) ..or share your File .. other approach to control you have Mops fallof.. Quote Link to comment Share on other sites More sharing options...
natalia Posted January 19, 2022 Share Posted January 19, 2022 Hey Breadbox, try resampling the wav file in the file node. I believe you don't have enough samples by the looks of your screenshot Quote Link to comment Share on other sites More sharing options...
