vellum bendstiffness give strange value ?
sebkaine
Hi guys,
i don't understand what is the internal math done by bendstiffness.
i have a scene with stiffness set to 1 + stiffness multiplicator to 1.
then i have a point attribute bendstiffness that i use as a scale multiplicator set between 10000 and 0.0001.
i was expecting to get my stiffness between 10000 and 0.0001 but it give me weird values.
to get what i want i had to bypass the feature and do it with a wrangle.
I would be curious to know if someone could explain me why i get those strange values. I have attach a HIP that describe the pb.
Thanks for your time
Cheers
E
kStiffness.hip
Ok gotcha :
As effective changes in stiffness requires painting over orders of magnitude, this has a logarithmic effect.
i don't exactly know what it is , but i'm sure it explain the problem. houdini doesn't do a scale with a basic mult but instead use logarithmic math.
anyway i don't like it cause it introduce unexpected value that i have not ask. i will use the wrangle option to be sure to control exactly the value i want.
Cheers
Edited by sebkaine
  • Thanks 1
