Sprite Scale
nomad
hello everyone.
i have done a sprite shader of smoke.
Sprite is scaling in time with expression rand($FF + $PT)/4 -
result is very roughly scale. It looks like flicking of image. t is not good :angry: .
How can i do random more smoothand more accurate ??
Should i adjust the expression?? if so,suggest me, i am not so clever in code :blink: . :blink:
Or may be solution is to drive the sprite scale from CHOP by noise or wave?????
or something else :blink: ??
I saw it. My sprites based just on this lesson. But never the less. In this tutorial the same problem. I want more smoothly :angry:
Hi Nomad,
The reason it's "flickering" is because you are taking the random value based on a frame number. the rand() function in Houdini produces pseudo-random (it needs to be pseudo-random in CG else result is unpredictable everything). What you're probably looking for is noise(), this will give you a smoother noise appearance here.
HOpe that helped.
Hi Nomad,
HOpe that helped.
noise is perfect for this situation, but you can try with sturb too, it uses different mathematics algorithms that gives you spatial coherency, that is, and smooth and pseudo random variation.
There are several noise based funtions like noise, snoise, turb, sturb, try them.
thank you for your advices :) .
-grasshoper - it is only my mistakes, ofcourse, in any chance "type" must be "float".
Noise is really perfect for this situation. But. I came into collision with problem that i have never seen elier.When the particles biths - they appears very suddenly.
test.rar
It looks bad :angry: .
I want to make appearense by degrees, like smoke or steam. How can i do it better ???
My gain is to birth sprites fluent and then over a period of animation to drive them by expression "noise($TX, $TY, $TZ)".
Have i change a value of spritescale depending on particle life ???? And how in this case expression will looks like??? Or this problem can be solved on VOPs level???
Sure, sombody somehow had such problem.
Without spending any thinking on my part :ph34r: , would something like any of the following help:
noise($TX+$LIFE, $TY+$LIFE+3, $TZ+$LIFE+5) -- where each position is offset by particle life.
noise($TX, $TY, $TZ)*(1-$LIFE) -- where the noise is scaled by life of the particle
Not sure if that's what you're looking for... my brain has pretty much went to sleep at this hour. <_<
To make particles appear less suddenly you could fade them in by ramping up the alpha. Add a color POP, click on the Alpha tab and check Ramp. You'll probably want to drive the lookup with LIFE. You can also control the pcsale during the particle's life. Normally for smoke and such your pscale will grow during the particle's life and the alpha will fade in quickly and out slowly. Hope that's what you were looking for.
john.
