philippecounter Posted January 27, 2022 Share Posted January 27, 2022 Hello everyone, I hope you are well I have a little problem and I can't find the solution.... I would like to be able to create a gradient ramp on my left object (the 8), in order to be able to assign it a color, black in the center, white on the extremities (as on the right plane). Is there a function in the wrangle attribute for that? Thanks in advance 8.hiplc Quote Link to comment Share on other sites More sharing options...
animatrix Posted January 28, 2022 Share Posted January 28, 2022 Hi, You can use Distance Along Geometry SOP, feed border points by grouping unshared points and even use a ramp parameter to further tweak the values: Quote Link to comment Share on other sites More sharing options...
philippecounter Posted January 28, 2022 Author Share Posted January 28, 2022 You are the best, thank you very very very very much 1 Quote Link to comment Share on other sites More sharing options...
