Stop Sweep from interseting itself
raincole
With Sweep SOP, I swept this profile:
Over this curve:
And got this:
Now how could I get rid of this self-intersection? I know I can manually remove some points from the original curve, but is there a more procedural way? Like to detect the "concave" part of the curve and adjust their orientation?
probably not working in every situation, but you can collect all points, which have a sharp corner. Once you have these points, you can clip the geometry by the dividing planes (u-value aswell). The clipping part should be restricted to the intervals between each corner.
Sweep_avoid_intersection.hipnc
using carve can be another option, to split the curve into several parts (applied sweep), which can be merged together, after the ends are clipped by the planes.
Sweep_avoid_intersection_segments.hipnc
Edited by Aizatulin
  • 3 weeks later...
On 2/8/2022 at 11:38 PM, Aizatulin said:
Clever! Thank you very much.
