Vellum Rest Length Scale Per Connected Piece
RyanJP
Hello, I'm using Vellum Source to emit multiple spheres over time and I want to increase the Rest Length Scale of each individual sphere every frame, starting at 1 (for each piece) and incrementing. Realized I have no idea how to select individual bits of sourced geo within DOPs and can't seem to find it anywhere online. Thank you!!
Hey Ryan,
You can use a SOP solver inside the dopnet to create an increasing attribute/value that can be used to drive the rest length scale. The attribute will be created and starts increasing once a new sphere gets emitted.
I hope this is what you're looking for! ^_^
emitting_vellum_restscale.hiplc
On 2/26/2022 at 10:42 AM, Ziyad said:
Hey Ryan,
So, following up on this because I can't see much info online about this subject. So let's say I wanted each piece to have it's own "@maxRestScale" and once that value is achieved it stops incrementing. I've got the attributes assigned to the constraints just fine, but how can I pass them into DOPs to be used to affect the rest scale?
Inside the SOP solver again, you can append a connectivity node so each sphere has a unique class attribute, then use that class attribute to create a random value that would be assigned as the "@maxRestScale", then in DOPs add an if statement to make sure the incrementing stops (as in the rest length scale stops increasing) once rest length scale exceeds the "@maxRestScale".
Edited by Ziyad
  • Thanks 1
