Heat Transmission Possible?
I want to do a heat transmission animation.
Similar to what those engineering software like Ansys can do, but with a more complex structure.
example img.
I guess this is not something like CFD, but more like transmission inside solids.
Is it possible to do in Houdini? Don't have a clue how...
2 hours ago, NabilJ said:
I'm not sure if I understand exactly what you need.
An attribute transfer will surely do the job ?
In this example it transfers the Cd attribute on the inside boxes too
My bad. To explain it a bit clearer, I want to use Houdini as a simulation tool, for instance, like the vellum system.
In this case, say, I have two plates (or more complex structures). I want to see how heat is transmitted in the material (how fast, how distributed, etc.) by tuning some parameters of the material.
(For instance, I can tune the stiffness of material in FEM sim to have different deformation results).
23 hours ago, Librarian said:
Thanks.
I'm actually aware of the wave function.
I didn't go for this for two reasons:
1. it works better for surface propagation, while my structure is more like a "tree-like" structure, where a lot of rots are connected, but no a "solid" volume.
2. Not easy to implement these differential equations in discrete form.
That's why I asked here to see if there are build-in nodes for this kind of purpose.
  • 2 weeks later...
@xarthur if you search on Berlin Math Houdini you gonna find DEC_heat_with_boundaries(solver) Python with SciPy.
bdy_d_val = np.array(geo.pointIntAttribValues("bdy_d_val"))
bdy_n_val = np.array(geo.pointIntAttribValues("bdy_n_val"))
# read time step
time_step = geo.attribValue("time_step")
# read matrices
d0 = cache_node.cachedUserData("d0")
star1 = cache_node.cachedUserData("star1")
star0 = cache_node.cachedUserData("star0")
star0inv = cache_node.cachedUserData("star0inv")
# build
L = -d0.transpose().dot(star1.dot(d0))
D = star0inv.dot(L)
# index slice instructions
indB = np.flatnonzero(bdy_d)
indI = np.flatnonzero(bdy_d==0)
# slice the matrix
LI = L[indI,:]
LIB = LI[:,indB]
LII = LI[:,indI]
star0 = star0 + L - L # convert from diag
star0I = star0[indI,:]
star0IB = star0I[:,indB]
star0II = star0I[:,indI]
# slice vector
uI = u[indI]
# solver pre
n = LII.shape[0]
lhs =  star0II - time_step*LII
rhs = star0II.dot(uI) + time_step*LIB.dot(bdy_d_val[indB]) + time_step*star0II.dot(bdy_n_val[indI])
# linear solve
out = la.cg(lhs,rhs)
# assign solution
solI = out[0]
u[indB] = bdy_d_val[indB]
u[indI] = solI
# save to attribute
hou.Geometry.setPointFloatAttribValues(geo,"u", u )
# read time step
# read matrices
# build
D = star0inv.dot(L)
# slice the matrix
LI = L[indI,:]
LIB = LI[:,indB]
LII = LI[:,indI]
# slice vector
uI = u[indI]
# solver pre
n = LII.shape[0]
# linear solve
# assign solution
solI = out[0]
u[indI] = solI
# save to attribute
Hi, really appreciate the help.
But would you mind sharing the original source of this script?
I searched "Berlin Math Houdini" and different combinations of keywords including "heat" or "solver",but cannot find something similar.
I also went over their blog: http://wordpress.discretization.de/houdini/ , nothing either...
Edited by xarthur
typo.
The problem is that I googled that "DEC_heat_with_boundaries", but got nothing...
Then DuckDuckGo gives me a lot of results...
Seems google is banning some results based on my location???
But anyway, got what I want. Thank you!
