Intersection detection and realignment? Help
crispr_boi
Hi, I am not sure how to explain this well, so apologies in advance.
I have this basic cactus generator, there are clusters of thorns, at their base the thorns intersect with each other, which I currently don't mind, because I will solve or hide that later..
However I don't want the tips of the thorns to intersect with the tips of thorns from other clusters, as this is easily observed.
Is there a way to place each thorn or cluster of thorns after the other and check if there are any intersections, after a new cluster has been placed and if yes rotate and maybe scale the intersecting thorn(s) until there are no more intersection?
Like that cycle through all the clusters?
I know my scene might not be set up well to do that..
Would that be expensive to calculate and/or difficult to implement?
I attached the hip file, and an illustration to clarify what I mean:
base_cactus.hiplc
Edited by crispr_boi
Mispelling
