Potpourri3d and numpy
Librarian
thanx to Asia forums
potpourri3d_pointCloud
node = hou.pwd()
geo = node.geometry()
import numpy as np
import potpourri3d as pp3d
P = np.array([geo.pointFloatAttribValues("px"), geo.pointFloatAttribValues("py"), geo.pointFloatAttribValues("pz")])
P = np.stack((P), axis = 1)
# = Stateful solves
#P = # a Nx3 numpy array of points
solver = pp3d.PointCloudHeatSolver(P)
# Compute the geodesic distance to point 4
dists = solver.compute_distance(4)
geo.setPointFloatAttribValuesFromString("dist", dists.astype(np.float32))
# Extend the value `0.` from point 12 and `1.` from point 17. Any point
# geodesically closer to 12. will take the value 0., and vice versa
# (plus some slight smoothing)
ext = solver.extend_scalar([12, 17, 33], [0.0, 0.5, 1.0])
geo.setPointFloatAttribValuesFromString("ext", ext.astype(np.float32))
# Get the tangent frames which are used by the solver to define tangent data
# at each point
basisX, basisY, basisN = solver.get_tangent_frames()
# Parallel transport a vector along the surface
# (and map it to a vector in 3D)
sourceP = 0
ext = solver.transport_tangent_vector(sourceP, [1., 0.])
ext3D = ext[:,0,np.newaxis] * basisX +  ext[:,1,np.newaxis] * basisY
ext3dx = ext3D[:,0]
ext3dy = ext3D[:,1]
ext3dz = ext3D[:,2]
geo.setPointFloatAttribValuesFromString("ext3dx", ext3dx.astype(np.float32))
geo.setPointFloatAttribValuesFromString("ext3dy", ext3dy.astype(np.float32))
geo.setPointFloatAttribValuesFromString("ext3dz", ext3dz.astype(np.float32))
# Compute the logarithmic map
logmap = solver.compute_log_map(sourceP)
logmapu = logmap[:,0]
logmapv = logmap[:,1]
geo.setPointFloatAttribValuesFromString("logmapu", logmapu.astype(np.float32))
geo.setPointFloatAttribValuesFromString("logmapv", logmapv.astype(np.float32))
geodesicDistance_pointCloud
node = hou.pwd()
import numpy as np
startpt = geo.intAttribValue("startpt")
# = Stateful solves
dists = solver.compute_distance(startpt)
geodesic_distances_mesh
node = hou.pwd()
# Add code to modify contents of geo.
# Use drop down menu to select examples.
import numpy as np
# mesh N*3 Array
#points' coordinates (P)
#prims' points - primpoints()
F = np.array([geo.primIntAttribValues("vert0"), geo.primIntAttribValues("vert1"), geo.primIntAttribValues("vert2")])
F = np.stack((F), axis = 1)
#solve for geodesic distances
solver = pp3d.MeshHeatMethodDistanceSolver(P,F)
#write out distance per point into dist-pointattribute
