Adam Ferestad Posted March 14, 2022 Share Posted March 14, 2022 I am working to build a tool which contextualizes updates options in a multiparm block based on an option selected in the block itself. I have been able to get ahold of the information for which index in the multiparm everything is going and have been able to extract information just fine, but I cannot seem to update the UI. I really feel like I am just missing a function somewhere in the documentation. Right now I'm essentially doing this to update what I have now: def load(): node = hou.pwd() ptg = node.parmTemplateGroup() baseAttribs = ["list", "pulled", "in", "from", "elsewhere"] multiparm = hou.FolderParmTemplate("attrib", "Attrib Item", folder_type = hou.folderType.MultiparmBlock) collapsibleFolder = hou.FolderParmTemplate("settings#", "Settings", folder_type = hou.folderType.Collapsible) attribList = hou.MenuParmTemplate("root_attribs#", "Select Attribute", tuple(baseAttribs), menu_labels=tuple(baseAttribs), script_callback="hou.phm().attribType(kwargs)", script_callback_language=hou.scriptLanguage.Python, menu_use_token=True) collapsibleFolder.addParmTemplate(attribList) multiparm.addParmTemplate(collapsibleFolder) multiparm.setDefaultValue(1) ptg.appendToFolder(ptg.findFolder("JSON Settings"), multiparm) node.setParmTemplateGroup(ptg) def attribType(kwargs): node = hou.pwd() p = kwargs["parm"] parent = p.parentMultiParm() multiParmIndex = int(kwargs['script_multiparm_index']) menuIndex = int(kwargs['script_value']) container = parent.parmTemplate().parmTemplates()[0] selected = p.menuItems()[menuIndex] a = hou.LabelParmTemplate("test#", f"Testing that this works {multiParmIndex} {selected}") container.addParmTemplate(a) I know what the name should be and I have the correct multiparm index from within kwargs, which is amazing. So how can I put things into the collapsible folders? For the first entry I know I have the settings1 folder and I want to add in that label, but I cannot seem to figure out how to do that. Quote Link to comment Share on other sites More sharing options...
