Concatenating Strings And Floats
cspears2002
My instructor showed me an expression:
bbox(strcat("../xform_move_me_", atof(opdigits(".")-1)), D_XMAX)
My confusion stems from the following:
/ -> exhelp opdigits
float opdigits (string name)
/ -> exhelp atof
float atof (string source)
Will forcibly convert a string into a float
According to exhelp, both functions return floats. In
just about every programming or scripting language I
know of, concatenating a string and a float results in
an error. Why doesn't the bbox expression above cause
some sort of error?
/ -> exhelp atof
some sort of error?
Actually there are plenty of languages out there that do implicit type conversions based on context which is what hscript is doing here. strcat needs strings as arguments so if it sees integers or floats it simply converts them for you. Perl is a good example of a language where implicit type conversions like this are common. For example, in Perl you can have:
$string = "Hello"			  # Quotes denote strings
$int = 42					  # No quotes denote integers or floats
print $string . $int
> Hello42
/ -> exhelp atof
some sort of error?
As grasshopper already noted, the "str" expressions convert the arguments on the fly to a string type. For example, if you did:
strcat("foo","1")
strcat("foo",1)
strcat(foo,1)
strcat(foo,"1")
the result is always foo1.
What I didn't understand in your expression was the section atof(opdigit(".")-1) . You are right that opdigit returns a float so I'm not sure why you'd put the atof before it. It still evaluates the same if you remove the atof.
