playfight Posted April 2, 2022 Share Posted April 2, 2022 Hello I'm trying to turn a pop wind object on/off. I first tried to just keyframe it, but then I get smooth values between 0 and 1 and all i want is on and off. I then noticed there is a handy 'use VEXpressions' box in there. but I do not know how to access 'Activation'. The editor does not like Activate, Active, Activation, with or without an @ Symbol. The SideFX help pages seem to indicate this is possible, but without showing how to do it. https://www.sidefx.com/docs/houdini/nodes/dop/popwind.html#parameters This is what I tired: if(@Frame == 1 || 20) { @Activate = 1; } if(@Frame == 10 || 30) { @Activate = 0; } Quote Link to comment Share on other sites More sharing options...
Ziyad Posted April 3, 2022 Share Posted April 3, 2022 Hello, You can type your expression straight into the activation parameter, the activation value will be 1 if the condition you put is true and 0 if it's false. For example the expression below will result in the wind being activated for the first 30 frames only 1 Quote Link to comment Share on other sites More sharing options...
dleonhardt Posted April 3, 2022 Share Posted April 3, 2022 When dealing with "use VEXpressions" boxes, the node will expect the name of the parameter, not the label, without an @. In your case this would be if(@Frame == 1 || 20) { activate = 1; } To find out the name of a parameter, you just hover over the label and it'll say "Parameter: name_of_the_parameter" 1 Quote Link to comment Share on other sites More sharing options...
playfight Posted April 5, 2022 Author Share Posted April 5, 2022 thanks Ziyad, I thought of doing this but abandoned it because I wasn't sure if I could have a more complex logic statement in there for turning it on/off. I guess it would work if I just wanted it to be turned on at a certain frame. Or can you put more complex statements (like something with curly braces) in a box like that? I will try it sometime and see. dleonhardt - I thought I had already tried this, but sure enough, I type it out once again as you have indicated here, and it works! I didn't know about finding those parameters by hovering over the label, but I did stumble upon 'activate' as the name (which I why I thought I had tried it) by peering inside the Edit Parameter Interface. but that is a good tip to remember, much faster than opening up the interface. Now I'm wondering if it is possible to access the wind X velocity with windx (like windx = 10) I'm trying it now - no errors, but its not procing results either. It could be due to some other setting like amplitude or gravity, etc. thank you both for the excellent suggestions and speedy responses Quote Link to comment Share on other sites More sharing options...
