How can I reverse rigdoctor?
shinsso
KineFX uses vertex order to set hierarchy. A reverse SOP will flip the hierarchy. Make sure it's wired in before the first rig doctor. Once you add a rig doctor, additional attributes are added that define parent and child indices and local transforms are calculated using that hierarchy. Adding a reverse SOP after that won't have any effect.
  • Like 2
Thank you so much for your detailed reply. It was a big help.
