jmquintela Posted May 21, 2022 Share Posted May 21, 2022 I'm exporting a pointcloud of instances to test if everything holds up on others houdini versions or apps so I can be shure if I'm on production and need to share sequences with coworkers they work correctly... so I test bgeos and Alembics.. and I found a problem with rotations misalignment for wich I can't find a solution.. I test with a copy node if my output is correct and it is.. but when I do the same on hou 17 they are not I use orient attribute.. maybe I should convert orient to N and Up via Vex..but I guess the result will be the same.. Is there a robust and universal way of exporting the point rotations to make shure they will be correctly interpreted by any other app?? I attach the scene in a zip, is made with some MOPs because is my main case focus.. I don't think the problem is there, but I leave them anyways... test.zip Quote Link to comment Share on other sites More sharing options...
