jamesearnest244 Posted May 22, 2022 Share Posted May 22, 2022 Hi, Can anyone explain what the temperature attribute does in FLIP sims? Quite surprisingly, this attribute is not documented in the help files for the FLIP object. Thanks! Quote Link to comment Share on other sites More sharing options...
ryew Posted May 22, 2022 Share Posted May 22, 2022 It's useful if you want to modify viscosity by diffusing temperture values, for example melting an object. Try the "Melt Object" shelf tool on a sphere to check out how the Gas Temperature Update DOP uses it inside the DOP network Quote Link to comment Share on other sites More sharing options...
