attach script to default node buttons
mProv
Hi,
I'd need to customize the behaviour of the default buttons of some nodes, e.g. - display a custom message when I press "Save to Disk" on a rop_alembic.
Also, I want the script to run for all the users in my studio. Maybe should I create a preset from this and save it in the shared HOUDINI_PATH?
Beyond the fact I'm not sure how to do it on a custom buttom I may create in the parameter interface, all the default parameters are locked.
Can someone help me?
thanks
it seems you have to edit built-in otl to achieve the function,i'm not sure it's safe for houdini built-in nodes,so not recommended,
but you can custom buttons or otls, here are basic steps for custom otl,
1) create a .py file in $HOUDINI_USER_PREF_DIR/pythonX.7libs, code it like this:
import hou
def onButtonPress():
    #print("you pressed the button")
    hou.ui.displayMessage("hello,button pressed")
2) create arbitrary otl,add a button parameter
3) edit otl contents:
    edit operator type properties->scripts->event handler "python module"
    add codes like this,
 def press():
	import button_press
	button_press.onButtonPress()
    then,on parameters tab set "callback script" to "hou.phm().press()", done.
and you can ref these sections,
callback
Modules on disk
Hi Benyee,
thank you for the reply. Well actually my problem is in fact that people is not using the custom HDA and pipeline tool, that's why I'd like to edit the built-in stuff. For some ROPs I was thinking about using the pre-render script, and then block the parameter in order to prevent anyone to edit it again. But obviously if there is any better idea I'm happy to hear it.
I really don't know how to handle flipbook tho... Basically I want people to use them just to see stuff on the fly, but if they want to save out images on the server they have to use the pipeline tool. Unfortunately everyone is basically ignoring it and saving out the image sequences by hand, resulting in wrong paths, names...
