gemini Posted June 14, 2022 Share Posted June 14, 2022 Hi !! Is there a way to replace 'Geometry' text at the Network Editor ? Cheers, Szabolcs Quote Link to comment Share on other sites More sharing options...
ikoon Posted June 14, 2022 Share Posted June 14, 2022 That text is generated by the nodegraphtitle.py file in the install directory: C:\Program Files\Side Effects Software\Houdini 19.0.622\houdini\python3.7libs\nodegraphtitle.py You can copy that file into the custom python3.7libs directory (any of your active packages or here C:\Users\info\OneDrive\Documents\houdini19.0\python3.7libs\nodegraphtitle.py ) and edit the source code. Quote Link to comment Share on other sites More sharing options...
gemini Posted June 14, 2022 Author Share Posted June 14, 2022 Cool! I check! Quote Link to comment Share on other sites More sharing options...
