Noise scale along 1 axis
Hello everyone)
I try to make cliffs from yotube tutorial, but cant find how can i change  noise scale along one axis in houdini 19.
In previus versions whas option inside mountain node called scale. Where it is now?)
I know what i can use attribute wrangle for some thing like this
float val = noise(@P * set(ch("scale"), 1, 1));
@P.y = val;
But i whant to use noise attribute noise or mountain and just scale it by vertical axis, for examle. ow can i do it?)
I don't wanna use wrangler because i don't know how to control noise same simple as it can be done in attribute noise
I try to find answer in google about 2 hours what i do wrong?))
Edited by TreeMeen
10 hours ago, mestela said:
Нажмите маленькую кнопку XYZ в конце параметра «размер элемента», он разделит один элемент управления масштабом на 3.
Thanks, it worked))
