Point() For Undefined Point
rdg
Hello,
I am not sure how to articulate my question, so please skip it if it's too uncoordinated.
I copy boxes onto a particle system.
I have a NULL with a spare channel animation.
I stamp the following expression onto the boxes sz:
cht("../null1/growth", point("../popnet1", $PT, "life", 0))
so far so good: the boxes scale after birth.
Now I plug a grid instead of the popnet into the second input of copy.
The popnet doesn't birth as much particles.
The boxes where PT exits for a grid point and a particle act like I expect.
For all others where no particle exists all scale like the last particle.
I would expect them not to scale at all as I cannot get a life for a particle that doesn't exist, do I?
Maybe a popnet returns always the last acessible particle and not undefined?
Thank you.
Georg
rdg_growth.6.hipnc
That does seem strange a little strange.
I tried the same thing with just a grid and a point expression
/obj/model/grid2 -> echo `point(".",150,"P",0)`
The grid only has 100 points but when quering the position of a
point that's out of range it returns the value from the highest (in terms of point number) existing point.
might be a bug, might be by design.
Doesn't really matter just, add more points to your popnet :)
Luca
Bug or design?
Luca & Steven,
thanks for your answers.
I'd vote for design as this behaviour is less error-prone.
Otherwise you would have to use try()catch() like stuff
if(point()!=undefined, point(), foo())
Thanks for remixing my hip.
It took me while to re-engineer it.
Why do you use the attribtransfer, you still need point() to get the life?
Georg
If I get the attribute via attribute transfer it doesn't return values for undefined points.
That is a reason to use attributeTransfer.
I first thought attributetransfer would make the point() expression obsolete and provide $LIFE.
Thanks.
Georg
