Cannot access attribute of point inside the wrangle in which it is created
Wondering why this behavior exists:
I create a bunch of points in a Detail wrangle using this code.  After the loop, when trying to print the value of any point attribute, it always returns {0,0,0}.
If I wire in a second wrangle and try to print the value using the same last two lines of code, the P vector prints correctly.
What is the logic behind this?
int i;
for (i=0; i<100; i++){
float x = rand(i);
float y = rand(i*2);
float z = rand(i*3);
vector v = set(x,y,z);
addpoint(geoself(), v);
vector val = point(geoself(), "P", 5);
printf("%g", val);
Edited by JH12
Because the geometry creation happens after the entire VEX code is executed and the result is finalized as the output of that particular wrangle. So you don't have those geometry actually created while you are still in the same VEX kernel, but after. That's why you can't use them in the same code that used to create them.
