Scaling geometry on birth frame with VEX
NoaX
Hey everyone,
I have a bit of an interesting challenge here, and would love to see if someone has a better approach than mine to achieve the desired result.
You have a series of geometry that is being 'birth' at random points, at random frames as such:
The desired result is to identify when the pieces are born, and scale them from each-points center, 0-100% for 24 frames. (Open file I have an example of desired results)
FILE:  post_scale.hiplc
thank you!
