Shader Based On Normals
Hi Everybody....
I am trying to create a Terrain Shader. I have written Displacement shader, and facing a problem while writing surface shader. I want to shade the surface based on the slope, say Green for Horizontal surface and Red for vertical surface. Polygon Normal's Y component varies from 0 to 1 for Horizontal To Vertical. So I have a Spline which has Normal.Y as the input. It is giving me result, but the shader is changing as I move the camera. I tried all space combinations inside Vops. But not working. What can be the problem???
----iamjaideep80
Jaideep Khadilkar
TD, Sciclone Motion Graphics
  iamjaideep80 said:
Hi Everybody....
----iamjaideep80
Jaideep Khadilkar
This is just guessing:
The Colors change because the normal you use depends on the camera.
You could add a explicit normal attribute reference this in your shader.
Georg
