AlexAlex Posted October 1, 2022 Share Posted October 1, 2022 Is it possible to animate pscale using vellum grains? I am using the setup from this video https://entagma.com/abstract-particle-animation-using-houdini-vellum-octane-render/ I have it so I am able to randomize the pscale now, but if I try to adjust the pscale inside the vellum solver via a pop wrangle or geo wrangle, it will just scales infinitely either positive or negative. Animation outside the solver seems to be ignored. Thank you. Quote Link to comment Share on other sites More sharing options...
Benyee Posted October 2, 2022 Share Posted October 2, 2022 you can animate it in SOP and read it into DOP by either Geo Wrangle or SopSolver normally just as animating other attribs animate_vgrain_pscale.hip 1 Quote Link to comment Share on other sites More sharing options...
AlexAlex Posted October 2, 2022 Author Share Posted October 2, 2022 5 hours ago, Benyee said: you can animate it in SOP and read it into DOP by either Geo Wrangle or SopSolver normally just as animating other attribs animate_vgrain_pscale.hip Thanks so much for making this for me! That is what I wanted. I wonder if it is because I am using vellum sop solver and something is different... Quote Link to comment Share on other sites More sharing options...
Benyee Posted October 4, 2022 Share Posted October 4, 2022 (edited) On 2022/10/3 at 5:33 AM, AlexAlex said: I wonder if it is because I am using vellum sop solver and something is different... I think you can read in animated attribs in vellum sop solver as well using the similar approach,but somethimes the result may be different from DOP workflow's SOP vellum workflow is actually DOP workflow but limited by default vellum sop solver has no multisolver,so by default you can just modify data in vellum solver, but you can do it after vellum solver by bringing in multisolver animate_vgrain_pscale_v2.hip Edited October 4, 2022 by Benyee 1 Quote Link to comment Share on other sites More sharing options...
AlexAlex Posted October 6, 2022 Author Share Posted October 6, 2022 On 10/4/2022 at 9:40 AM, Benyee said: I think you can read in animated attribs in vellum sop solver as well using the similar approach,but somethimes the result may be different from DOP workflow's SOP vellum workflow is actually DOP workflow but limited by default vellum sop solver has no multisolver,so by default you can just modify data in vellum solver, but you can do it after vellum solver by bringing in multisolver animate_vgrain_pscale_v2.hip Thank you so much again for your help and file! Very helpful. I realized that I was scaling them incorrectly inside the vellum solver, treating them like dumb particles, I was using @pscale *= chf("mult"); , of course every frame it was reading that and multiplying it by a certain degree and flying off into forever. Quote Link to comment Share on other sites More sharing options...
