lavitz01 Posted October 14, 2022 Share Posted October 14, 2022 I am using the trial to evaluate the render. I am missing the shaders in the shop, and mat contexts and I have no vop for Arnold. I have the dropdown menu and the rop. in the dropdown, it is missing the lights and volume creation that redshift has. I am assuming these are missing too. here is my hou.env # # NOTE: The use of packages is highly recommended instead of houdini.env # See details about packages here: https://www.sidefx.com/docs/houdini19.5/ref/plugins.html # # Houdini Environment Settings # # The contents of this file are read into the environment # at startup. They will override any existing entries in # the environment. # # The syntax is one entry per line as follows: # VAR = VALUE # # Values may be quoted # VAR = "VALUE" # # Values may be empty # VAR = # # Example: # # HOUDINI_NO_SPLASH = 1 # htoa config start PATH = "$PATH;C:/Users/lavit/htoa/htoa-6.1.3.2_r2bc6797_houdini-19.5.368.py37/htoa-6.1.3.2_r2bc6797_houdini-19.5.368.py37/scripts/bin" HOUDINI_PATH = "C:/Users/lavit/htoa/htoa-6.1.3.2_r2bc6797_houdini-19.5.368.py37/htoa-6.1.3.2_r2bc6797_houdini-19.5.368.py37;&" # htoa config end Quote Link to comment Share on other sites More sharing options...
