Modern example for Midi In
I know there is an example called Midi Out in the doc, but it's really dated, and it doesn't even work as is. In Midi In chop,
Error
Could not open the MIDI interface.
I think it's supposed to rotate the keys around their X axis using data from a file or something ? I don't get it
Can you show me a way to read a Midi file and animate something with it ?
Last time I tried, I could only see some data with: ' Echo messages to textport ' activated, but I didn't manage find the channel where the midi data ended.
Edited by AntoineSfx
  On 11/3/2022 at 6:46 PM, flcc said:
Here is a test file I do some time ago. it's based on the doc example, but a bit more clear.
Working in H19 (not tested 19.5)
Midi files for test are included.
Midi Automations.zipFetching info...
Definitely working here in 19.5
So that' s worth studying. Thanks.
