possible? maintain original scale and orientation upon instancing
anicg
I attach the hipfile.
Here is what I've done: starting from an exact orientation for each shape (only 2), I turned each into a point and tried to render as instances instead of having the duplicate geometry, but I loose the orientation when I instance to the points. I do not want to have random orientation. It MUST be the exact same place, the exact same scape, the exact same orientation as the original.
Is it possible?
instance.hiplc
Instancing looks for attributes on those points, otherwise it doesn't know how Pos Rot Scale should look like. You can go very different ways about this. The easiest is to probably save your transforms as a transform attribute and set all transforms on your points to zero. See attached scene. I marked the changed nodes yellow.
instance_yader.hiplc
Thank you. I've tried to use "Each Connected Piece"  instead of chasing each piece separately with transform and attribute promote, but it doesn't seem to work.
I get a file imported that has a lot more pieces as input, without their individual transform nodes, too many to work on each manually. Any advise?
Edited by anicg
I attach a new hip file to show the problem.
[instance_v2.hiplc] is the original but with file nodes which matches the kind of imported input.
[instance_v2 method not working.hiplc] is where I apply the method you've given with a for each connected piece, but but it doesn't work.
There are usually a lot more individual pieces than 3 or 4. These are only for demonstration purposes, easily hundreds per combo in reality.
instance_v2.hiplc
combo1.bgeo.sc
combo2.bgeo.sc
shape2.bgeo.sc
shape1.bgeo.sc
Edited by anicg
You can use the Extract Transform Sop for that. It just needs the objects once with transforms applied
and once without any transforms and calculates a proper transform attribute for each of them useable while instancing.
You can either use the foreach approach or copy your reference object as much as you have target geometry, both methods work.
instance_v2_yader.hiplc
